VEYE-MIPI-IMX335 Data Sheet
VEYE-MIPI-IMX335 DATA SHEET
VEYE-MIPI-IMX335 is a starlight video streaming module, using a compact design (38*38*18mmm) to facilitate user integration, standard 15pin FPC user interface, easy access to embedded platforms such as raspberry pi and Nvidia.
VEYE-MIPI-IMX335
  • 1/2.8 inch 5Mega sensor IMX335LQN-C by SONY
  • MIPI output: CSI-2
  • IR-CUT circuit
  • Stream mode
  • BLC, 2D/3D noise reduction
  • Also support 5V, 3.3V independent power supply (Pay attention to the power of the power supply terminal)
VEYE-MIPI-IMX335
3 Thechnical Detail
Technical Details
SENSOR
Sensor SONY IMX335LQN-C STARVIS
Pixels 5.04M pixel
Resolution 2592(H) × 1944(V)
Image Size Diagonal 6.52 mm (Type 1/2.8)
Unit Cell Size 2.0 μm (H) × 2.0 μm (V)
Output Format RAW Bayer
Shutter Type Rolling Shutter
SNR1s Value 0.33lx
ISP
Frame Rate 5M(2592x1944P)@20fps、5M(2592x1944P)@12.5fps
Exposure Auto / FLK / Manual
White Balance Auto or Manual
Image Enhancement BLC
Lens & IR-CUT
Lens MTV12 / MTV16 / CS
Interface
Video Data Interface MIPI:2 Data Lanes@1188Mbps, CSI-2 YUV422-8bit Data Type
MIPI CSI-2 DC Specifications
General
Operating Conditions
(Bare PCB)
-10℃~60℃, Humidity 95% or less, non-condensing
Power Supply 5VDC / 3V3DC
Power Consumption Usually: 1.6W@4M30fps
IR_CUT action switching moment: 2.1W MAX
Dimension 38mm*38mm*18mm(not include lens and lens mount)
Sensor Spectral Sensitivity
IMX335LQN-C
IMX335LQN-C Spectral Sensitivity
5 Connector Pinlist
VEYE-MIPI-IMX335
VEYE-MIPI-IMX335
J1:CSI-2 Interface
Pin NO. NAME Remarks
2 MIPI_L0_N
3 MIPI_L0_P
5 MIPI_L1_N
6 MIPI_L1_P
8 MIPI_CK_N
9 MIPI_CK_P
11 NC
12 NC
13 SCL 3.3V level
14 SDA 3.3V level
15 VCC3V3 PWR IN
J4 : Day/Night External Trigger
3 IMAGING STATUS OUTPUT,3.3V:Color;0V:MONO
J3 : IRCUT Control Functional specifications
2 IRCUT2 +
2 IRCUT2 -
J7:5VDC INPUT
1 5VDC
J5:Auxiliary IIC
1 AUX_SCL
3 AUX_SDA
6 Board Dimension
CAD drawing unit : mm
下载dwg图纸
7 PCBA 3D STP File
download VEYE-MIPI-IMX335-MBRD 3D STP file
download VEYE-MIPI-IMX335-SBRD 3D STP file
