VEYE-MIPI-IMX462 DATA SHEET
The VEYE-MIPI-IMX462 is a compact single board design (38*38mm) for easy integration. The standard 15pin FPC user interface enables easy access to embedded platforms such as Raspberry Pi 、Nvidia、NXP IMX8M.
- 1/2.8 inch 2 Mega STARVIS sensor IMX462LQR-C by SONY
- MIPI output: CSI-2
- Uncompressed UYVY / YUYV format, YUV422-8bit
- Standard lens mount
- IR-CUT circuit
- Framerate control
3 Thechnical Detail
Technical Details
SENSOR
Sensor
SONY IMX462LQR-C STARVIS
Pixels
2.07M pixels
Resolution
1920*1080
Image Size
Diagonal 6.46 mm (Type 1/2.8)
Unit Cell Size
2.9um (H)*2.9um(V)
Output Format
RAW Bayer
Shutter Type
Rolling Shutter
SNR1s Value
0.18lx
ISP
Frame Rate
1080p@25 / 1080p@30fps
Exposure
Auto or Manual
White Balance
Auto or Manual
Shutter
1/25(1/30)s to 1/50,000s
Slow Shutter
Support
Denoising
Image Setting
Brightness, Contrast, Sharpness, Saturation,Flip, Mirror
Image Enhancement
BLC, DOL-WDR, Defog
Day/Night Switch
Manual or IR-CUT filter with external trigger
Lens & IR-CUT
Lens
MTV12 / MTV16 / CS
Lens Mount
M12*P0.5 / M16*P0.5 / CS,IRCUT is optional
Mounting Hole
2 screw holes with diameter of 2.2mm,20mm Center-to-Center Spacing
Interface
Connector
15Pin 1.0mm pitch FPC, upper contact
Communication Interface
IIC, 3.3VDC
Video Data Interface
MIPI:2 Data Lanes, CSI-2
UYVY / YUYV format YUV422-8bit Data Type, Bandwidth 1.188Gbps
MIPI CSI-2 DC Specifications
IR-CUT Control
IR-CUT motor control, 3.3VDC
Day/Night External Trigger
3.3VDC to 12VDC compatibility
General
Operating Conditions
(Bare PCB)
Power Supply
3.3VDC or 5VDC
Power Consumption
Usually: 1.05W
IR_CUT action switching moment: 1.5W
Dimension
38mm*38mm*11mm(not include lens and lens mount)
Sensor
IMX462LQR-C
IMX462LQR-C Spectral Sensitivity
The response characteristics of IMX462LQR-C much better than IMX327LQR-C in the near infrared
5 Connector Pinlist
J3:CSI-2 Interface
Pin NO.
NAME
Remarks
GND
MIPI_L0_N
MIPI_L0_P
GND
MIPI_L1_N
MIPI_L1_P
7
GND
8
MIPI_CK_N
9
MIPI_CK_P
10
GND
11
RST
Active Low,reset camera module
12
NC
13
SCL
3.3V level
14
SDA
3.3V level
15
VCC3V3
PWR IN
J2 : Day/Night External Trigger
Pin NO.
NAME
Remarks
Day&Night Signal In
INPUT,Active Low(Image to MONO),3.3VDC to 12VDC compatibility
GND
NC
J4 : IRCUT Control Functional specifications
MODE
Pin NO.
PIN NAME
Signal polarity
Image type
Filter position
Mode 1
IRCUT1
color
Infrared cutoff
IRCUT2
Mode 2
IRCUT1
mono
Full wavelength pass
IRCUT2
J6:5VDC INPUT
Pin NO.
NAME
Remarks
5VDC
GND
J7:Auxiliary IIC
Pin NO.
NAME
Remarks
AUX_SCL
GND
AUX_SDA
6 Board Dimension
下载dwg图纸
7 PCBA 3D STP File
download 3D STP file
