VEYE CS Camera on MYIR i.MX8 board
MYD-JX8MX development board from MYIR Technology uses i.MX8M processor, MYD-C8MMX uses i.MX8M Mini processor.
On the basis of MYIR's official SDK(L4.19.35 version), our camera module driver is added, and some application layer routines are provided.
Series Model Status Adaptor board
VEYE series VEYE-MIPI-IMX327S Done ADP-MYiR
VEYE series VEYE-MIPI-IMX385 Done ADP-MYiR
VEYE series VEYE-MIPI-IMX462 Done ADP-MYiR
CS series CS-MIPI-IMX307 Done ADP-MYiR
CS series CS-MIPI-SC132 Done ADP-MYiR
We use ADP-MYiR to connnect MYD-J8XMX board.
MYiR-MYD-J8XMX connection overview
MYiR MYD-JX8MX connection details
3 Upgrade MYD-JX8MX system
3.1 Overview
This section describes how to update the MYD-JX8MX system to support our camera module. To support our camera module, we need to update two parts of the system, Image and DTB.
3.2 BSP package introduction
3.2.1 i.MX platform bsp
includes:
  • driver source code
  • i2c toolkits
  • application demo
3.2.2 MYiR i.MX platform bsp
https://github.com/veyeimaging/myir_nxp_i.mx
includes:
  • prebuild linux kernel:Image
  • dts source code
3.3 Burn the MYIR standard system
Refer to : MYD-JX8MX-Software-Manual-zh-V1.3.pdf
Burn the standard system provided by MYIR to the board.
The Image and dtb files of the MYD-JX8MX board are saved in the FAT partition of emmc. After the system is started, it is automatically mounted to the /run/media/mmcblk0p1/ directory.
On HOST PC:
git clone https://github.com/veyeimaging/myir_nxp_i.mx.git
Extract the kernel Image, and copy the Image and dtb files to the MYD-JX8MX board.
cp <your path>/Image /run/media/mmcblk0p1/
cp <your path>/myb-fsl-imx8mq-evk-veye327.dtb /run/media/mmcblk0p1/myb-fsl-imx8mq-evk.dtb
Reboot MYD-JX8MX board.
4 Applications and Test
4.1 Check system status
  • VEYE-MIPI-IMX327S
camera veye327_mipi is found
Registered sensor subdevice: veye327_mipi <0/1>-003b
  • CS-MIPI-IMX307
dmesg | grep csimx307
camera csimx307_mipi is found
Registered sensor subdevice: csimx307_mipi <0/1>-003b
  • CS-MIPI-SC132
camera cssc132_mipi is found
Registered sensor subdevice: cssc132_mipi <0/1>-003b
video0 or video1
The cameras of the two MIPI-CSI2 interfaces are identified and mounted to i2-0 and i2c-1 respectively.
4.2 List the modes supported by the camera
v4l2-ctl --list-formats-ext -d /dev/video<0/1>
4.3 Video Stream test
  • Preview (VEYE-MIPI-IMX327S,CS-MIPI-IMX307 @1080p mode)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1920,height=1080,framerate=(fraction)30/1' ! waylandsink
  • Preview (CS-MIPI-IMX307 @1080p mode 10fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1920,height=1080,framerate=(fraction)10/1' ! waylandsink
  • Preview (CS-MIPI-IMX307 @720p mode 60fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1280,height=720,framerate=(fraction)60/1' ! waylandsink
  • Preview (CS-MIPI-SC132 @1280*1080 mode 45fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1280,height=1080,framerate=(fraction)45/1' ! waylandsink
  • Preview (CS-MIPI-SC132 @1080*1280 mode 45fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw,width=1080,height=1280,framerate=(fraction)45/1' ! waylandsink
  • Snap a picture (VEYE-MIPI-327S,CS-MIPI-IMX307 @1080p mode)
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, width=1920,height=1080' ! jpegenc ! filesink location=test_image.jpg
  • Snap a picture (CS-MIPI-IMX307 @720p mode)
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, width=1280,height=720' ! jpegenc ! filesink location=720p.jpg
  • Snap a picture (CS-MIPI-SC132 @1280*1080 mode)
gst-launch-1.0 v4l2src num-buffers=1 device=/dev/video0 ! 'video/x-raw, width=1280,height=1080' ! jpegenc ! filesink location=test_image.jpg
  • v4l2grab snap a picture(VEYE-MIPI-327S,CS-MIPI-IMX307 @1080p mode)
4.4 I2C Control Toolkits Manual
  • VEYE series
  • CS series
The following operations are done on Ubuntu Host PC.
5.1 Set up the Host PC environment
Refer to the official document MYD-JX8MX-Software-Manual-zh-V1.3.pdf to deploy the development environment.
Note that you don't have to use yocto if you only want to compile kernel, Of course, there is no problem with using yocto.
5.1.1 Cross-compiling Toolchain
There is a compiler tool chain installation script in the 03-Tools directory, which can be executed directly.
./fsl-imx-xwayland-glibc-x86_64-meta-toolchain-aarch64-toolchain-4.19-warrior.sh
After installing the compilation tool chain, execute the following command to configure the compilation environment:
source /opt/fsl-imx-xwayland/4.19-warrior/environment-setup-aarch64-poky-linux
5.2 Build MYIR version kernel
Copy the officially provided fsl-release-yocto.tar.gz to the development host and extract it.
The source code for linux is already available in the fsl-release-yocto/linux-imx directory.
cd fsl-release-yocto/linux-imx
make ARCH=arm64 CROSS_COMPILE=aarch64-poky-linux- defconfig
make ARCH=arm64 CROSS_COMPILE=aarch64-poky-linux- -j4
5.3 Patch code
  • Driver source code
The source code path of the camera driver is: linux/drivers/media/platform/mxc/capture, places the source code of the camera driver in the corresponding directory.
Merge the Config and Makefile in the same path. Add the corresponding camera driver.
  • dts file
Modify the Config and Makefile in the same path. Add the corresponding dts option.
5.4 Add compilation options
make menuconfig
Add the compilation options for the corresponding camera module driver, and the path is Device Drivers > Multimedia support > V4L platform devices > MXC Camera/V4L2 PRP Features support.
5.5 Build
make Image dtbs -j4
6 References
MYIR official site:http://www.myir-tech.com/
MYD-JX8MX : http://down.myir-tech.com/MYD-JX8MX/
