ADP-MV1-V2 Adapter Board Data Sheet
Adapter Board:ADP-MV1-V2 DATA SHEET
转接板:ADP-MV1-V2 数据手册
1 Introduction 产品介绍
The ADP-MV1-V2 board function is connector interface conversion, user IO, power IO,IIC etc,signal lead out.
The ADP-MV1-V2 converts FPC 30pin interface of MV-MIPI-XXX camera to 22pin interface,Compatible with raspberry Pi or Nvidia CSI-2 interface.
The ADP-MV1-V2 converts the power IO, trigger input and user IO pins in the FPC30 interface of the MV-MIPI-XXX series cameras into 2.54 pins and MX1.25 connectors for easy testing and integration.
ADP-MV1-V2板的功能是将连接器接插件方式转换,用户IO、电源IO、IIC等信号引出。
ADP-MV1-V2板将 MV-MIPI-XXX系列工业相机的FPC30接口转换为FPC22接口,兼容树莓派或者英伟达的CSI-2接口。
ADP-MV1-V2板将 MV-MIPI-XXX系列工业相机的FPC30接口中的电源,触发输入,用户输出等引脚,转换为2.54插针和MX1.25连接器,易于测试、集成。
2 Product Picture 产品图片
| PART NUMBER / 型号 | FRONT VIEW / 正面图片 | BACK VIEW / 背面图片 | Camera Support / 适配摄像机模组 |
| ADP-MV1-V2 | MV-MIPI-IMX178M |
3 Board Pinlist 引脚说明
| J1: CSI-2 Interface,Compatible with raspberry Pi or Nvidia CSI-2 interface
J1:CSI-2接口,兼容树莓派或者英伟达CSI-2接口 | ||
| 1 | VCC3V3 | 3.3V PWR IN |
| 2 | SDA | 3.3V Level |
| 3 | SCL | 3.3V Level |
| 5 | NC | |
| 6 | SYS_RSTn | System reset,3.3V Level |
| 8 | MIPI_L3_P | |
| 9 | MIPI_L3_N | |
| 11 | MIPI_L2_P | |
| 12 | MIPI_L2_N | |
| 13 | GND | |
| 14 | MIPI_CK_P | |
| 15 | MIPI_CK_N | |
| 16 | GND | |
| 17 | MIPI_L1_P | |
| 18 | MIPI_L1_N | |
| 19 | GND | |
| 20 | MIPI_L0_P | |
| 21 | MIPI_L0_N | |
| 22 | GND | |
| J2:Up Contact, Connect to MV-MIPI-XXX Industry Camera J3
J2: 上接触,连接MV-MIPI-XXX系列工业相机 J3 | ||
| 2 | VCC | 5V |
| 3 | VCC | 5V |
| 4 | VCC | 5V |
| 5 | VCC | 5V |
| 6 | GND | |
| 7 | ENABLE | Camera Power Enable |
| 8 | GND | |
| 11 | GND | |
| 14 | GND | |
| 17 | GND | |
| 18 | MIPI_L2_N | Reserved 预留 |
| 19 | MIPI_L2_P | Reserved 预留 |
| 20 | GND | |
| 21 | MIPI_L3_N | Reserved 预留 |
| 22 | MIPI_L3_P | Reserved 预留 |
| 23 | GND | |
| 24 | SCL_MV | I2C SCL, 3.3V Level |
| 25 | SDA_MV | I2C SDA, 3.3V Level |
| 26 | GPIO3 | Reserved 预留 |
| 27 | USER IO2 | Multi-function Port 2,3.3V level;可配置输出2,3.3V电平标准 |
| 28 | USER IO1 | Multi-function Port 1,3.3V level;可配置输出1,3.3V电平标准 |
| 29 | TRIGGER_I | Hardware Trigger in,3.3V level;硬件触发输入,3.3V电平标准 |
| 30 | GND | |
| J3:Auxiliary Expansion Port 1
J3:辅助扩展口1 | |||||
| 1 | VCC | 板内连接到 J2-2 | 2 | GND | |
| Links 相关链接:
mv_mipi_i2c.sh user guide:IO Control en | |||||
| J4:Auxiliary Expansion Port 2
J4:辅助扩展口2 | ||
| 6 | GPIO3 | 板内连接到 J2-26 |
| 8 | NC | |
| 9 | NC | |
| Links 相关链接:
