GX Camera on Firfly Boards
How to use the GX series cameras on the Firefly board
This article uses the Firefly ROC-RK3588S-PC, ROC-RK3576-PC, and ROC-RK3566-PC boards as examples to describe how to connect GX series cameras to RK3566/RK3568, RK3576, and RK3588S/RK3588-based systems.
Linux drivers are provided for the GX series cameras, with Ubuntu used as the reference operating system.
GX series GX-MIPI-IMX662 Done
1.2 Supported boards
manufacturers model status
Firefly ROC-RK3588S-PC Done
Firefly ROC-RK3576-PC TBD
Firefly ROC-RK3566-PC TBD
Firefly boards use a 30-pin camera connector, while GX series cameras feature a 22-pin interface and require an independent 5 V power supply. Therefore, a dedicated FFC adapter cable and a separate power cable have been designed to support proper connection and power delivery.
2.1 Connection Diagram
GX Camera to Firfly
GX Camera to Firfly
3 Introduction to the GitHub Repos
3.1 General part of the Rockchip platform
includes:
  • driver source code
  • i2c toolkits
  • application demo
3.2 Firefly Board–Related Resources
This repository mainly includes the following contents:
  • Device Tree Source (DTS) files and compiled DTB files
  • Driver compilation and build instructions
3.3 Board Image Flashing
Precompiled Linux system images are provided in the GitHub Releases section.
For the ROC-RK3566-PC, ROC-RK3576-PC, and ROC-RK3588S-PC boards, we provide release-version system images for flashing.
Please locate the system image corresponding to your specific board that includes support for GX series cameras from the previously mentioned download paths.
Refer to the official Firefly documentation (ROC-RK3588S-PC ROC-RK3566-PC ROC-RK3576-PC) for detailed instructions on flashing the system image.
5 Check system status
5.1 Camera Detection
After completing the system installation and connecting the camera hardware, power on the system. On the Firefly board, execute the following command to verify whether the camera has been detected correctly:
$ dmesg | grep gxcam
There should be similar prompts like the following:
[6.667547] gxcam 7-003b: veye gx series camera driver version: 01.00.01
[6.781681] gxcam 7-003b: camera is: GX-MIPI-IMX662
[6.820210] gxcam 7-003b: Success to get gxcam endpoint data lanes, dts uses 2 lanes,will set to camera
[6.834597] gxcam 7-003b: gxcam_enum_controls success
[6.891209] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_gxcam 7-003b:bus type 5
From the log messages above, it can be confirmed that the detected camera model is GX-MIPI-IMX662.
The identifier 7-003b indicates that the camera is connected to I²C bus 7 with an I²C address of 0x3b.
  • On the ROC-RK3588S-PC, the camera is connected to i2c-7
  • On the ROC-RK3566-PC and ROC-RK3576-PC, the camera is connected to i2c-4
Next, execute the following command to check the video device node:
If the output shows:
this indicates that the camera has been successfully registered as /dev/video0.
At this point, both the camera hardware installation and driver setup are complete. For further application development, please refer to the following sections.
7 References
  • ROC-RK3566-PC Manual
  • ROC-RK3588S-PC Manual
  • ROC-RK3576-PC Manual
  • Firefly Linux User Guide
8 Document History
  • 2025-12-20
The document format was adjusted, it was appropriately polished.
  • 2025-11-28
The first version.
