How to upgrade the Jetson system to support VEYE cameras
| Series | Model | Status |
| GX series | GX-MIPI-IMX662 | Done |
In addition, the driver for the Fpdlink and V-by-One HS connection mode has been finished.
1.2 Jetson Board List
| Jetson Board | Status |
| Nano A02 | Done |
| Nano B01 | Done |
| Nano 2GB | Done |
| TX2 NX | Done |
| XAVIER NX | Done |
| TX2 Devkit | Done |
| AGX Xavier | Done |
| AGX Orin | Done |
| Orin NX | Done |
| Orin Nano | Done |
Note: For the GX series cameras, we have currently only ported the driver to the Orin Nano, Orin NX, and Xavier NX platforms.
1.3 Supported L4T versions
- Jetpack4.6.1,L4T r32.7.1
- Jetpack4.6.3,L4T r32.7.3
- Jetpack4.6.4,L4T r32.7.4
- Jetpack4.6.5,L4T r32.7.5
- Jetpack5.0.2,L4T r35.1
- Jetpack5.1,L4T r35.2.1
- Jetpack5.1.1,L4T r35.3.1
- Jetpack5.1.2,L4T r35.4.1
- Jetpack5.1.3,L4T r35.5
- Jetpack5.1.4,L4T r35.6
- Jetpack6.0,L4T r36.3
- Jetpack6.1,L4T r36.4
- Jetpack6.2,L4T r36.4.3
- Jetpack6.2.1,L4T r36.4.4
- Jetpack6.2.2,L4T r36.5
1.4 How to check the current L4T version
On Jetson board
2 Jetpack version differences
- Jetpack4.x versions
- Jetpack5.x versions
The dtb can also be loaded dynamically as an overlay. Refer to the official nVidia Developer's Guide for NVIDIA® Jetson™ Linux for details.
- Jetpack6.x versions
The drivers are no longer compiled into the Image but are loaded into the system as independent modules.
The dtb is also no longer compiled together as a whole but is dynamically loaded using the OVERLAYS mechanism. The advantage of this approach is that it better accommodates third-party boards.
3 Special Notes for Camera Module
- MV series camera
For the MV series modules, to support extended data types and external trigger modes, it is necessary to add relevant features to the existing system in addition to adding the camera driver.
For Jetpack 4.x and Jetpack 5.x, we have added the relevant features to the Image, so updating the Image is required.
For Jetpack 6.x, the new features are presented as independent drivers, so updating the driver files is necessary.
- GX series camera
For GX series modules, if the trigger functionality is not used, there is no need to update the existing kernel.
However, if external trigger mode support is required, the kernel must be updated—just as with the MV series—to enable trigger functionality.
4 BSP package introduction
4.1 Path
4.2 bsp package includes:
- driver source code
- dts source code
- i2c toolkits
In release packages
- prebuilt linux kernel:Image
- prebuilt camera drivers
5 DTB file corresponds to Jetson boards
5.1 Nano A02
5.2 Nano B01 Devkit
5.3 Nano B01 4G emmc
5.4 Nano 2GB
5.5 TX2 Devkit
5.6 TX2 NX(p3509-0000 carrier board)
5.7 AGX XAVIER
5.8 XAVIER NX Devkit
Specially, For Jetpack5.x, must use this dtb:
5.9 AGX Orin
5.10 Orin NX
5.11 Orin Nano
6 DTB file name and camera module correspondence
Specially:
3,MV-MIPI-MVCAM is the common dtb for all MV series and RAW series cameras, excluding RAW-MIPI-AR0234M and RAW-MIPI-IMX462M..
4,gxcam is a universal driver and device tree blob (dtb) for all GX-series cameras.
7 Upgrade directly on the jetson board
7.1 Check the current L4T version
It means L4t Verion is 32.4.3
7.2 Note about L4T 32.7. 2
In addition, the upgrade requires updating cboot, please refer to the FAQ section.
7.3 Download the bsp package to the Jetson board
On Jetson Board:
Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tar.gz
7.4 Upgrading drives
7.4.1 For Jetpack4.x
Just upgrade the Image, no need to install separate modules.
Backup old version Image
For Xavier NX Devkit
sudo cp <path to your Image dir>/Image* /boot/Image -f
Effective after restart.
7.5 For Jetpack5.x
Users of MV or RAW series cameras should first upgrade the Image to the Jetpack 4.x version, as detailed in the previous section. Then, follow the steps below to install the modules.
Check linux version:
uname -r
Find the corresponding directory in nvidia_jetson_veye_bsp/ko :
- Specially,for Jetpack5.1 version:
- Specially,for Jetpack5.1.1 version:
Upon completion of the copy operation, invoke the following command to register the modules into the system:
sudo depmod
7.6 For Jetpack6.x
uname -r
sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/downstream/i2c/* /lib/modules/$(uname -r)/updates/drivers/media/i2c/ -fIf either of the following two conditions applies, additional drivers need to be installed:
- Using an MV or RAW series camera.
- Using a GX series camera and wishing to use external trigger mode.
sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/downstream/terga-camera/tegra-camera.ko /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera -f
sudo cp nvidia_jetson_veye_bsp/ko/$(uname -r)/upstream/*.ko /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/ -f
sudo depmod
Note: Since both the Jetpack 6.2.1 , Jetpack 6.2 and Jetpack 6.1 versions have the same kernel version number (5.15.148-tegra), the drivers for Jetpack 6.2.1 are placed in the 5.15.148-tegra-l4t36.4.4 directory,the drivers for Jetpack 6.2 are placed in the 5.15.148-tegra-l4t36.4.3 directory.
7.7 For Jetpack6.2.1
Therefore, for Jetpack 6.2.1, the following commands should be modified as:
sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/downstream/i2c/* /lib/modules/$(uname -r)/updates/drivers/media/i2c/ -f
1. Using an MV or RAW series camera.
2. Using a GX series camera and wishing to use external trigger mode.
sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/downstream/terga-camera/tegra-camera.ko /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera -f
sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.4/upstream/*.ko /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/ -f
sudo depmod
7.8 For Jetpack6.2
sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.3/downstream/i2c/* /lib/modules/$(uname -r)/updates/drivers/media/i2c/ -f
sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.3/downstream/terga-camera/tegra-camera.ko /lib/modules/$(uname -r)/updates/drivers/media/platform/tegra/camera -f
sudo cp nvidia_jetson_veye_bsp/ko/5.15.148-tegra-l4t36.4.3/upstream/*.ko /lib/modules/$(uname -r)/kernel/drivers/media/v4l2-core/ -f
sudo depmod
7.9 Specialized handling of FPDlink interface cameras(JP5.x and JP6.x)
If using a camera module with fpdlink interface. You must manually control the loading order to ensure that ds90ub954.ko is loaded before the camera driver is loaded.
After the system boots, manually insert the drivers in order, e.g.
sudo insmod ds90ub954.ko
sudo insmod veyecam.ko
The command to load the driver can be added to the startup script.
7.10 Upgrade dtb
7.10.1 For Jetpack4.x and Jetpack5.x
sudo mkdir /boot/veyecam/
Under the bsp package directory, find the dtb or dtbo file corresponding to your camera module model and L4T version number.
Note: <DTB file name> should be replaced with the corresponding dtb name of the mainboard(When entering, do not include the <> symbols.), ensure that the file specified in the FDT line actually exists correctly.
7.10.2 For Jetpack6.x
In Jetpack 6.x system, support for preserving the existing device tree blob (dtb) and adding our camera's dtbo as an overlay will greatly facilitate adaptation to third-party versions of the mainboard.
First, identify the currently valid dtb files:
ls /boot/dtb
Edit the `/boot/extlinux/extlinux.conf` file, adding two lines at the bottom to specify the main dtb and the overlay we want to add.
For instance, for the Orin NX Devkit using the VEYE-MIPI-IMX462:
FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
OVERLAYS /boot/veyecam/tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo
for the Orin NX Devkit using the RAW-MIPI-AR0234:
OVERLAYS /boot/veyecam/tegra234-p3737-camera-raw_ar0234m-overlay.dtbo
for the Orin Nano Devkit using the MV series cameras:
FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb
Or
FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
OVERLAYS /boot/veyecam/tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo
8 Upgrade Jetson Board using Host PC
This method is complicated and not recommended for Nano, Xavier, Orin.
8.1 Burn the standard Image
- Set PATH
- Xavier NX Devkit
8.2 Download our bsp package for Jetson
8.3 Upgrade Image and DTB
Extract the downloaded `nvidia_jetson_veye_bsp.tar.gz`, and locate the Image corresponding to the specific version.
- Installing the Kernel
- Nano and TX2
on the Host PC:
on the Host PC:
- Flashing dtb file
9 Are Image and DTB upgrade successful ?
9.1 For DTB
9.1.1 Jetpack4.x and Jetpack5.x
- AGX Xavier/AGX Orin
- Orin NX, Orin Nano,Xavier NX and TX2 NX(p3509-0000 carrier board)
9.1.2 Jetpack6.x
- Orin NX and Orin Nano
ls /sys/firmware/devicetree/base/bus@0/cam_i2cmux/i2c@0/
- AGX Xavier and AGX Orin
ls /sys/firmware/devicetree/base/bus@0/i2c@3180000/tca9548@70/i2c@*
9.2 For Image
ls /sys/bus/i2c/drivers/
When installing the camera correctly, the relevant directory for the camera should exist, such as veyecam csx307 cssc132 mvcam gxcam, etc.
10 Protection against being overwritten by upgrades
11 FAQ and bug list
11.1 Problem of system update not taking effect on a system with an SSD hard drive
If an SSD hard drive is installed in a system and mounted on the / directory, it may cause regular system update operations (Image, ko, dtb) to be completely ineffective.
The reason for this is that the board comes with an eMMC storage device, and the Image, ko, and dtb that take effect during the boot stage are stored in the eMMC.
After the boot is completed, if the SSD hard drive is mounted on the / directory, it may cause the files stored on the eMMC to be inaccessible.
The solution in this case is to manually mount the mmcblk0p1 partition of the eMMC to a specific directory, and perform all system update operations based on this directory.
11.2 VEYE cameras on Jetpack5.x
11.3 CS-MIPI-IMX307 combined with Orin nano and Orin NX Green Screen
11.4 Jetpack5.0.1 DP
11.5 cboot of L4T32.7.2 on Xavier
12 Build the drivers from source
Please refer to: Nvidia Jetson platform VEYE camera driver source code compilation guide.
