Mv series camera appnotes 4 jetson
MV series MV-MIPI-SC130M Done
1.2 Jetson Board List
Jetson Board Status
Nano A02 Done
Nano B01 Done
Nano 2GB Done
TX2 NX Done
XAVIER NX Done
TX2 Devkit Done
AGX Xavier Done
AGX Orin Done
Orin NX Done
Orin Nano Done
1.3 Supported L4T versions
  • Jetpack4.6.1,L4T r32.7.1
  • Jetpack4.6.3,L4T r32.7.3
  • Jetpack5.0.2,L4T r35.1
  • Jetpack5.1,L4T r35.2.1
  • Jetpack5.1.1,L4T r35.3.1
  • Jetpack5.1.2,L4T r35.4.1
  • Jetpack5.1.3,L4T r35.5
  • Jetpack5.1.4,L4T r35.6
  • Jetpack6.0,L4T r36.3
  • Jetpack6.1,L4T r36.4
  • Jetpack6.2,L4T r36.4.3
  • Jetpack6.2.1,L4T r36.4.4
On Jetson board
Orin Nano
Orin NX
Orin Nano
Orin NX
ADP-MV1-V2
Support 4-lane
The two are connected using 0.5 mm pitch*30P FFC cable with Opposite-side contacts. The cable must be inserted with the silver contacts facing outside,Please refer to the physical connection diagram of the camera and the adapter plate ADP-MV1-V2.
2.1.2 Connection with Nano and NX using ADP-MV1
2.1.3 Connection with Orin Nano and NX using ADP-MV1
MV camera connect to Orin Nano and Orin NX
MV-MIPI-CAM to ADP-N4
2.2.2 Power supply
ADP-N4 to AGX XAVIER
ADP-N4 to AGX Orin
ADP-N4 to TX2 Devkit
RAW camera and Jetson Nano connection(15Pin)
RAW camera and Jetson Nano connection(15Pin To 22Pin)
Raw camera and ORIN NX connection(15Pin To 22Pin)
RAW camera and ORIN NX(22Pin)
RAW-MIPI-IMX462 connect with ADP-N5
ADP-N5 to AGX Xavier
3 Upgrade Jetson system
This patch has two features:
4 How to Use 4-Lane Mode
  • MV-MIPI-GMAX4002M
  • RAW-MIPI-SC535M
  • RAW-MIPI-AR0234M
4.3 Using the 4-Lane Mode DTB
For Orin NX devkit:
  tegra234-p3767-camera-p3768-veye_mvcam-dual-4lane-cam1.dtbo
  tegra234-p3767-camera-p3768-raw_ar0234m-dual-4lane-cam1.dtbo
5 Support for trigger mode
6 Check system status
6.1 /dev/videoX node
7 veye_viewer
8.1 Nano
8.2 TX2
8.3 XAVIER and Orin
Usage:
source ./mv_probe.sh
A typical output:
$ source ./mv_probe.sh
Setenv HEIGHT = 2048
echo $CAMERAMODEL
Important Notes:
Example:
10.1 Install v4l2-utils
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'UYVY'
        Index       : 1
        Pixel Format: 'NV16'
        Index       : 2
        Pixel Format: 'GREY'
        Name        : 8-bit Greyscale
        Index       : 3
        Pixel Format: 'XY10'
        Index       : 4
        Pixel Format: 'XY12'
Camera Controls
10.2.3 Trigger Mode
10.2.4 Trigger Source
10.2.6 Set frame rate
For example:
v4l2-ctl --set-ctrl roi_x=0
10.2.8 preferred_stride
10.3 Video Streaming mode
10.3.1 Set ROI and format
10.3.2 Frame rate statistics
10.3.3 Save image to file
10.3.3.1 Typically
  • raw8
  • raw10
  • raw12
10.3.3.2 MV-MIPI-IMX178M
  • raw8
  • raw10
  • raw12
10.3.4 Preview
10.3.4.1 Preview using qv4l2
Play mv camera using qv4l2
10.3.4.2 Preview using VLC
Install vlc,
sudo apt-get install vlc
Play mv camera using VLC
10.3.4.4 Gstreamer Usage
Previewing GREY format images using GStreamer
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)GRAY8, width=(int)1920, height=(int)1200" ! videoconvert ! xvimagesink sync=false
10.4 Trigger mode
10.4.1 Prepare
10.4.2 Software trigger mode
10.4.2.1 Set mode
10.4.2.2 Start acquisition
  • Typically
v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=-1 --stream-to="y8-${WIDTH}x${HEIGHT}.raw"
  • MV-MIPI-IMX178M
10.4.3 Hardware trigger mode
10.4.3.1 Hardware Connection
  • Using ADP-MV1
  • Using ADP-N4
ADP-N4 common trigger source
10.4.3.2 Set mode
10.4.3.3 Start acquisition
  • Typically
  • MV-MIPI-IMX178M
v4l2-ctl --set-fmt-video=width=3088,height=2064,pixelformat=GREY --stream-mmap --stream-count=1 --stream-to=y8-3104x2064.raw
python gpio_trigger_jetson.py
Note: script link.
11 Application demo
11.1 v4l2grab_mvcam_jetson
11.2.1 install yavta
11.2.2 Set ROI and format
11.2.3 Save image to file
11.2.3.1 Typically
  • raw8
  • raw10
Take XAVIER as example.
./yavta -c1 -F"y8-${WIDTH}x${HEIGHT}.raw" --skip 0 -f XY10 -s "${WIDTH}x${HEIGHT}" /dev/video0
  • raw12
./yavta -c1 -F"y8-${WIDTH}x${HEIGHT}.raw" --skip 0 -f XY12 -s "${WIDTH}x${HEIGHT}" /dev/video0
11.2.3.2 MV-MIPI-IMX178M
  • raw8
  • raw10
  • raw12
11.2.3.3 RAW-MIPI-SC535M
  • raw8
mv_mipi_i2c.sh user guide
13 References
14 Document History
  • 2025-07-02
  • 2025-03-23
Add support for mv_probe.sh.
  • 2024-08-13
Support Jetpack6.0.
  • 2024-05-22
Support Jetpack5.1.3.
  • 2023-08-16
  • 2023-07-31
Support V-by-One.
  • 2023-04-27
Support Jetpack5.1.1.
  • 2023-04-16
Remove flip function.
  • 2023-03-29
Add opencv samples.
  • 2023-03-37
  • 2023-02-22
Support Jetpack5.1
  • 2022-12-11
  • 2022-10-14
  • 2022-08-31
Support Jetpack5.0.2
  • 2022-06-23
  • 2022-05-20
