Mv series camera appnotes 4 rpi
MV series MV-MIPI-SC130M Done
2.1 MV series cameras use the ADP-MV1-V2 connection
MV series cameras need to use ADP-MV1-V2 adapter board in order to connect to Raspberry Pi.
2.1.1 Connection of MV series camera and ADP-MV1-V2
Both are connected by a 0.5mm pitch * 30P FFC flat cable on the same surface. Pay attention to the silver contacts facing side, Please refer to the physical connection diagram of the camera and the adapter plate ADP-MV1-V2.
2.1.2 Raspberry Pi 5, Raspberry Pi Zero 2W And other Raspberry Pis with 22-pin interfaces
Pay attention to the silver contacts facing side.
ADP-MV1-V2 to RPI5
ADP-MV1-V2 to RPI5
2.1.3 Raspberry Pi 4 And other Raspberry Pis with 15-pin interfaces
ADP-MV1-V2 to RPI4
3 piOS Configuration
raspi-config bullseye
4.1 libcamera and V4L2 mode
4.2 Legacy mode
5 V4L2 mode manual
5.2 Install driver
  • For Raspberry Pi 5
  • For other Raspberry Pi
Then reboot Raspberry Pi.
sudo cp driver_bin/$(uname -r)/veye_mvcam_4lane.dtbo /boot/overlays/veye_mvcam.dtbo
5.3 Uninstall the driver
5.4 Check system status
5.5 veye_viewer
Usage:
source ./mv_probe.sh
A typical output:
$ source ./mv_probe.sh
Setenv HEIGHT = 2048
echo $CAMERAMODEL
Important Notes:
Example:
5.7 Raspberry Pi 5 Setting
  • ./find_entity.sh
  • media_setting_rpi5.sh
./media_setting_rpi5.sh
This is a Raspberry Pi 5.
5.8.1 Install v4l2-utils
5.8.2 Install yavta
On Raspberry Pi 5, the actual supported image formats depend on the capabilities of the camera, not the list provided here.
5.8.3.3 Trigger Mode
5.8.3.4 Trigger Source
5.8.3.6 Set frame rate
5.8.3.7 Set ROI
  • method 1,use selection
v4l2-ctl --set-ctrl roi_x=0
5.9 Video Streaming mode
5.9.1 Set ROI
5.9.2 Set Framerate
5.9.3 Frame rate statistics
5.9.4 Save image to file
  • raw8
  • raw10
  • raw12
5.9.5 Preview
5.9.5.1 Preview using VLC
5.9.5.2 Preview using qv4l2
  • install opencv
pip uninstall opencv-python
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=GRAY8,width=$WIDTH,height=$HEIGHT,framerate=$FPS/1 ! videoconvert ! autovideosink
5.10 Trigger mode
5.10.1 Set ROI and Framerate
5.10.2 Software trigger mode
5.10.2.1 Set mode
5.10.2.2 Start acquisition
v4l2-ctl --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=5 --stream-to="y8-${WIDTH}x${HEIGHT}.raw"
5.10.3 Hardware trigger mode
5.10.3.1 Hardware Connection
5.10.3.2 Set mode
5.10.3.3 Start acquisition
python gpio_trigger.py
Note: script link.
5.11 Notes for CM4
5.11.1 Hardware Connection
5.11.2 Upgrade dt-blob.bin
dtoverlay=veye_mvcam
dtoverlay=veye_mvcam,cam0
CAM0 0 2lane video0
6 Legacy mode manual
Add executable permissions:
6.3 Camera power on
6.4 Preview
./mv_raspicam -t -1 -md 0
-md option data type
0 8bit Y
1 10bit Y
2 12bit Y
6.5 Save image
./mv_raspicam -t 1000 -md 0 -sr 10 -o /dev/shm/y8-3104x2064_%04d.yuv
6.6 Trigger mode
6.6.1 Software trigger mode
6.6.1.1 Set mode
6.6.1.3 Start acquisition
./mv_mipi_i2c.sh -w -f trgone
6.6.2 Hardware trigger mode
6.6.2.1 Hardware Connection
6.6.2.2 Set mode
Set rising edge trigger
6.6.2.4 Start acquisition
Note: script link.
6.7 Notes for CM4
  • Preview CAM0
./mv_raspicam -t -1 -c 0 -y 0
  • Preview CAM1
7 Raw data format
7.2 Packed image format
Packed raw data layer
7.3 Packed image size
7.4 Format convert tool
7.5 Raw data image player
7.6.1 Packed format details
7.6.2 Unpacked format details
mv_mipi_i2c.sh user guide
9 References
10 Document History
  • 2025-07-02
  • 2025-03-21
  • 2024-07-08
  • 2024-01-01
  • 2023-08-16
  • 2023-06-07
  • 2023-04-14
  • 2023-03-29
Add opencv samples.
  • 2023-03-26
  • 2023-03-04
  • 2023-02-10
Add note for CM4.
  • 2022-12-08
  • 2022-11-02
  • 2022-05-16
  • 2022-04-14
