RAW-MIPI-SC535M Data Sheet
RAW-MIPI-SC535M is a 5 million MONO industrial camera with MIPI interface.
- 2/3'' 5M SmartSens CMOS Sensor
- MIPI CSI-2 Interface
- Mono 8,Mono 10,Mono 12 Data Format
- 2lane,4lane mode
- Manual exposure mode
- Video streaming mode, Normal Trigger mode,Pulse Trigger Mode
- Support trigger delay, trigger number, and trigger interval,trigger count function
- Strobe synchronization
- ROI
3 Technical Detail
| Technical Details | |
| Sensor Type | CMOS |
| Shutter Mode | Global Shutter |
| Sensor | SC535HGS-MC3AN00 |
| Color | MONO |
| Image Size | 2/3'' |
| Unit Cell Size | 3.45um (H)*3.45um(V) |
| Resolution | Maximum: 2464(H) × 2064(V)
Typical: 2448(H) × 2048(V) |
| Max Frame Rate | 4lane@8bit mode:2448 x 2048 @83fps
| Gain | Analog Gain(HCG included):1x to 48x(0dB-37.8dB)
Digital Gain: 1x to31.9x (0dB-30dB) |
| Shutter Mode | Manual Exposure,Manual Gain |
| ADC Resolution | 12 bit |
| Pixel Format | Mono8,Mono10,Mono12 |
| ROI | Support |
| Working Mode | Video streaming mode(Free Running), Normal Trigger Mode, Pulse Trigger Mode |
| Trigger Source | Hardware,Software |
| Trigger Mode | Trigger Polarity,Trigger delay, Trigger number, Trigger interval,Trigger count |
| Strobe Mode | Strobe Output |
| Data Interface | MIPI CSI-2
Data Rate / lane:1188Mbps lane num:2 lane / 4 lane |
| Digital IO | Non-isolation IO:1 Trigger in,1 Strobe output,3.3V Level |
| Power Supply | 3.3V DC |
| Power Consumption | 500mW |
| Structure | |
| Size | Length * width * height = 29*29*7.9mm |
| Lens Mount | C-MOUNT03 ,S-MOUNT01 |
| Operating Conditions | |
| SC535HGS-MC3AN00 |
5 Interface & Pin list
| J9 : Camera MIPI CSI-2 | ||
| 1 | VCC3V3 | 3.3V PWR IN |
| 2 | SDA | 3.3V Level |
| 3 | SCL | 3.3V Level |
| 5 | NC | |
| 6 | SYS_RSTn | System reset,3.3V Level |
| 8 | MIPI_L3_P | |
| 9 | MIPI_L3_N | |
| 11 | MIPI_L2_P | |
| 12 | MIPI_L2_N | |
| 13 | GND | |
| 14 | MIPI_CK_P | |
| 15 | MIPI_CK_N | |
| 16 | GND | |
| 17 | MIPI_L1_P | |
| 18 | MIPI_L1_N | |
| 19 | GND | |
| 20 | MIPI_L0_P | |
| 21 | MIPI_L0_N | |
| 22 | GND | |
| J2:功能IO | ||
| 1 | Trigger In | Trigger Input,3.3V |
| 3 | Strobe Out | Strobe Output,3.3V |
6 Board Dimension
7 PCBA 3D STP File
