VEYE CS Camera on Firfly Boards
VEYE series and CS series cameras are the video streaming mode MIPI cameras we designed. This article takes Firefly's ROC-RK3566-PC,ROC-RK3576-PC and ROC-RK3588S-PC board as an example to introduce how to connect VEYE and CS series cameras to RK3566/RK3568/RK3576/RK3588 system.
In addition, the driver for the Fpdlink connection mode has been finished on the Ubuntu system.
2.3 Overall connection
Firefly Board and VEYE camera overall
FPDLINK Camera to RK3588S
includes:
  • driver source code
  • i2c toolkits
  • application demo
4 Ubuntu
4.1.1 Overview
For the kernel version 4.19, we provide a deb installation package that can be installed directly.
For the kernel version 5.10 and 6.1, we provide a burning image.
For versions where no installer is provided, you will need to refer to later chapters to compile from the driver source code.
4.1.2 kernel version 5.10 and version 6.1
For the ROC-RK3588S-PC and ROC-RK3576-PC, we have provided an image of the release system.
Download the latest released image file corresponding to the camera model you are using from https://github.com/veyeimaging/rk35xx_firefly/releases/ .
4.1.3 kernel version 4.19
On the RK35xx board,
4.2 Upgrade Firefly Ubuntu system(RK358x and RK3576)
4.3 Check system status
  • VEYE-MIPI-XXX
For ROC-RK3566-PC and ROC-RK3576-PC, the camera is connected to i2c-4, for ROC-RK3588S-PC to i2c-7.
4.4 Application examples
4.4.1 v4l2-ctl
4.4.1.1 Install v4l2-utils
4.4.1.3 Snap YUV picture
For RK3566, also:
Play YUV picture
4.4.1.4 Check frame rate
4.4.2 yavta
4.4.3 gstreamer
4.4.4 Import to OpenCV
First install OpenCV:
  • RK356x
  • RK358x
  • RK3576
https://github.com/veyeimaging/rk35xx_firefly/tree/main/linux/drivers/rk3576
  • VEYE series
  • CS series
6 Android
6.1 Update Android system
  • ROC-RK3566-PC
Download the latest rk356x_firefly_android.tar.gz from https://github.com/veyeimaging/rk35xx_firefly/releases/
  • ROC-RK3588S-PC
Download the latest rk358x_firefly_android.tar.gz from https://github.com/veyeimaging/rk35xx_firefly/releases/
6.2 Check system status
  • VEYE-MIPI-XXX
6.3 Application example
  • RK356x
  • RK358x
7 Known issues
  1. The VICAP module of RK3588 does not support outputting the UYVY format, so please use the NV12 format instead.
8 References
  • ROC-RK3566-PC Manual
  • ROC-RK3588S-PC Manual
  • ROC-RK3576-PC Manual
  • Firefly Linux User Guide
9 Document History
  • 2025-04-14
Support kernel v6.1 on RK3576.
  • 2024-04-17
  • 2023-05-22
Support Fpdlink-III on ubuntu system.
  • 2022-12-28
Add support for RK358x.
  • 2022-12-06
Support Android system.
  • 2022-10-22
